Hello All,
I am new to this SolarWinds APM... We are facing a typical problem... I am trying to search for a sentence in the log file and if that sentence is found, I am trying to send out an alert stating the sentence is found in the log file... Typically, a batch file executes in Application server at Midnight and that batch file creates a log in the log file related to it... Now, When I try to create a Log Parser to look for the log that is created by the batch file, then click on edit script and click on Get Script Output, I get an error that file not found... After that error is resolved, I tried to get the Script Output again and I get to see "==============================================Message: Can't find "regex" argument. Check documentation." error...
I either get File not found OR regex argument error...
Hope I am clear enough!
Any help would be appreciated...
Thanks!
Srini
Edited:
I am now observing a small problem... When I remove the search string (I think I spelled it correct, I mean the arguments we place after ^), I am observing the regex error... If I place the search string, I am observing an error as "File not found"...
Any correct way to place the script arguments? I entered it as \\10.1.1.14\test\logs\text.log,^Error
Let me know if I should be replacing it in other way..
Thanks!
