Hi there, been using SAM for the last month or so, and have a problem with it since upgrading to the latest version
I have all of the monitors correctly set up, but after a day or so, some of them turn to 'grey' unknown. The only way to get them to go back to up is to delete them and add them again. even if i go into the monitor and test it again the node it is currently 'unknown' for, the test passes as up - but when complete it still shows as grey.
NPM and SAM are installed on the same server and polling is all default.
Any help would be great
