When we are assigning the SQL Server 2005 template to monitor our nodes with SQL, the tests keep failing on the same part. It is the TCP Port Monitoring portion (the very last one). The error we get is the following: "no connection could be made because the target machine actively refused it." We have checked on the servers and TCP/IP is enabled to port 1433 which is the port this monitor is looking for. Has anyone else had this issue? Is the TCP Port Monitor really necessary for our SQL servers? Any help would be greatly appreciated.
