What severity level is recommended for Cisco ASA? Thoughts? We are seeing dropped connection and this feels informational.
Cisco ASA 5500 Series Configuration Guide using the CLI, 8.2 - Configuring Logging [Cisco ASA 5500-X Series Firewalls] -…
solarwinds appears to recommend "debugging"?
Integrate Cisco network devices with SolarWinds LEM - SolarWinds Worldwide, LLC. Help and Support
There are some messages only logged at higher levels (max = 7) that CAN be useful, so based on experience with a lot of customers that's where the initial recommendation got set. Starting at one step down (6) will get you almost everything and I think if you back down from there, you'll get less and less. (Cisco ASA 5500 Series Configuration Guide using the CLI, 8.2 - Configuring Logging [Cisco ASA 5500-X Series Firewalls] -…)
If you're looking at the message reference, the severity # is indicated in the log message - e.g. ASA-6-XXXXX - so you could spot check for those messages you know are most useful and work back from that. If there's nothing in severity 6 that is useful except for a single message, you can also adjust/promote the severity of a message.For example, if level 5 looks good but you really need ASA-6-123456, you can change 123456 to a 5 and leave your syslog levels at 5 (Cisco ASA 5500 Series Configuration Guide using the CLI, 8.2 - Configuring Logging [Cisco ASA 5500-X Series Firewalls] -… )
Good place to start would be syslog messages by severity: Cisco ASA Series Syslog Messages - Cisco
