I have been using this product for many years now and for the most part has always patched our servers perfectly. When Microsoft made the change and added exclusive updates this caused all kinds of issues. Finally to deal with this issue I ended up creating 2 tasks for each maintenance window:
1) Task 1 - Install all non exclusive updates and post reboot only if Windows update needs it.
2) Task 2 - (1 hour later) - Install exclusive updates and always reboot. This serves 2 purposes, patching system, and making sure no system is up for more than 30 days to help with system stability.
I have never been crazy about using this method because what if task 1 takes more than 1 hour? Would be nice if PM had some more logic capabilities for tasks.
How does everyone handle this issue?
The second issue I am having has to do with pending restarts. If Task 1 runs on a system that has reboots waiting the task will fail and the system will not patch. 1 hour later Task 2 will run and that will also fail because of the pending restart. That means that month the system missed its maintenance window and will not get patches. One option I have never fooled with and looks like it might help with this issue is the pre-update management option "Reboot only if required by Windows Update". I imagine this means if it's in a pending restart mode the task will reboot the system. My question is will the Task 1 re-run after the pre-reboot to actually initiate the patches? I asked support this question and they didn't have a definitive answer for me.
I brought this up with support several times but have never got any help. Once suggestion was to do something like the following:
1) Task 01 - Task to Reboot system.
2) Task 1 - (15 minutes later) - Install all non exclusive updates and post reboot only if Windows update needs it.
3) Task 02 - (1 Hour later) - Task to Reboot system.
4) Task 2 - (15 minutes later) - Install exclusive updates and always reboot.
I was not crazy with this solution once again as setting static times could cause timing issues.
My boss is on this new mission, and rightfully so, to automate more and reduce the amount of time we're wasting by performing manual processes.
Any help would be appreciated.
