I couldn't get hardware status with these servers: Dell EMC VxRail E560 , Dell EMC VxRail E560F , Dell EMC P570F , DELL PowerEdge R650 , DELL PowerEdge R750 even though i used the specific mibs
There is a KB article that clearly advises that the purpose of MIBS is not to identify devices (emphasis mine). You can see that here: https://support.solarwinds.com/SuccessCenter/s/article/What-is-a-MIB-OID-and-how-they-are-used?language=en_US and scroll down to the section "What are MIBs NOT used for".That said, now that you have the MIBs you can go out and create UnDPs for whatever you need.
You set up a custom undp poller with the proper oid/mib combo to get the metrics that you desired from these servers and nothing is returning? you probably did this, but have you confirmed the snmp data by running an snmpwalk to one of these from a polling engine? If that returns nothing at all - snmp is either blocked or not configured correctly (typo, what have you...). If it returns values that are not useful or no oids that you are looking for - that might be your problem. Good luck.
hi,
Have you found a solution to your problem?Now I am facing the same problem but no solvable solution.
Hardware status, or Hardware Health?
Hardware Health
Here's how to enable Hardware Health:
* https://documentation.solarwinds.com/en/success_center/orionplatform/content/core-enable-hardware-health-monitoring.htm
* https://documentation.solarwinds.com/en/success_center/sam/content/sam-asset-inventory-and-hardware-health-monitoring-requirements.htm
