HI all,
After many months of not really getting anywhere with SolarWinds support, could I ask this community a question regarding Orion memory usage.
What is normal memory usage for you on your orion application server, I understand every setup will be different and depends on modules, nodes monitored etc.
The reason being, we have NPM, NCM, VMAN, IPAM and VNQM, monitoring around 9500 elements on a physical server with 64GB. The recommended setup for this is 24GB and our memory increases over time and plateaus at 95%. I'm asking SolarWinds support if this is normal as we believe the services gets degraded when memory gets that high but support say unless services are failing its not a problem.
Do all of your environments slowly increase memory to near max?
Any info is much appreciated.
