Hello,
Just getting tired of figuring this out on my own, I am no DB guy.
I am attempting to get Peak VPN stats for a report from 4 ASA's built into a custom UdNP poller. I have the poller built, and can get this out from what I've figured out. As you can probably tell, I've been bouncing back and forth from MSSQL and SWQL. This is semi-working in SWQL, but I need a time period for today's date(current date), and a way to sum the queries from the four ASA's into one result. (And then also, it duplicated to produce two total results, with the second result being CurrentDate - 7 days.) Basically, Peak VPN usage for the current date and second result being Peak VPN usage the same day, a week earlier.
This...
SELECT MAX([RawStatus]) AS MAX_VPN_USERS
FROM
FROM [Orion.NPM.CustomPollerStatistics]
WHERE [CustomPollerAssignmentID] = '29daf78c-906b-4c64-bb8b-1563975527f6' AND DATETIME>=('2020-04-16') AND DATETIME<=('2020-04-17')
UNION
(SELECT MAX([RawStatus]) AS MAX_VPN_USERS
WHERE [CustomPollerAssignmentID] = '5c4be754-32b2-4efd-8e3f-ac06008d1382' AND DATETIME>=('2020-04-16') AND DATETIME<=('2020-04-17'))
UNION
WHERE [CustomPollerAssignmentID] = '0d79826d-9f33-4b97-ad41-34adb169cb23' AND DATETIME>=('2020-04-16') AND DATETIME<=('2020-04-17'))
UNION
WHERE [CustomPollerAssignmentID] = 'b15947fd-87df-46e0-b1ff-36b6b29afbdd' AND DATETIME>=('2020-04-16') AND DATETIME<=('2020-04-17'))
Results in this,
| | MAX_VPN_USERS |
| | 2139 |
| | 2798 |
| | 3007 |
| | 3665 |
which is Peak for the Datetime I have in each query for a period, but I just want that to be the current date(in Eastern Time), if that is a function, and then, of course to sum the four Peaks, which is the Only result I really want.
Any help would be appreciated.
