I've been auditing the monitoring of the myriad Cisco Switches, routers, DCI,OVTs etc. in my estate. It's a bit of a mess. I notice many of the devices have multiple IPs which is fine (routers etc.) but I also notice many of them respond to SNMP on multiple IPs. This seems to do two things that I would deem negative:
- There appears to be multiple nodes with different IPs that represent the same logical router/switch
- The auto-generated topology maps show the same node multiple times
I'm wondering if this is simply poor practice and I need to talk to the network admins and get them to define:
- A consistent naming convention for switches and routers
- Enable CDP/LLDP on L2 interfaces that connect switches and routers
- Define management networks and IPs
- polling networks
- disable CLI,SNMP on any other IPs
