It is possible from the NPM web console to swap or link to a different node details screen?
I would like to give users the ability to drill down into a node using the standard node details web page and then have the option to view node details using a custom node details web form.
I understand that I can use device type view but would like to maintain a standard node details form and then be able to move to another form that gives specific information on that particular device type
Thank you in advance
