Over the past 6 months I have convinced management to spend around $26K on software upgrades and a new dedicated database server for Orion. Now it looks like we need a bigger/better front end for Orion to run on. I need to design a server that will last us as I will be cut off after this purchase. Here is our current environment:
HP Blade Server
Dual-Core 1.8Ghz w/8 GB RAM running Windows 2003 Standard SP2
Orion SL2000 - 207 nodes and 755 interfaces (more will be added). Netflow with 77 interfaces. VoIP module (not currently active, but will be once we bring up new Cisco VoIP solution for 25 sites). We are also now looking at purchasing APM (not sure how many licenses).
I would like to jsut go ahead and size this new front end to have everything for Orion-SL2000 up and running so I am covered for future upgrades. We are also running 1 Engineer's toolset on this server and have syslog and traps being sent here. Cirrus is running on a separate VM, but it would be nice to have it on the same Orion server.
I know Orion is not yet a multi-threaded app and that is part of my issue, but can it now run on 64-bit OS? Would a blade server be appropirate or should I look for a standalone?
Support suggested a dual-core 3.0 Ghz server, but I want to make sure we will not outgrown it in 6 months as I am sure management is going to stop spending money on this app very soon until I get produce everything I have promised them. Any help in this matter is appreciated.
Thanks!
