I am currently evaluating Orion 8.1.0. When I expand some of the nodes, Orion Network Performance Monitor will freeze and I have to force the program to close. It gives me an application hang in the event log:
Event Type: Error
Event Source: Application Hang
Event Category: (101)
Event ID: 1002
Date: 7/24/2007
Time: 8:48:18 AM
User: N/A
Computer: NMS
Description:
Hanging application OrionNetPerfMon.exe, version 8.1.0.3, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 48 61 6e 67 ion Hang
0010: 20 20 4f 72 69 6f 6e 4e OrionN
0018: 65 74 50 65 72 66 4d 6f etPerfMo
0020: 6e 2e 65 78 65 20 38 2e n.exe 8.
0028: 31 2e 30 2e 33 20 69 6e 1.0.3 in
0030: 20 68 75 6e 67 61 70 70 hungapp
0038: 20 30 2e 30 2e 30 2e 30 0.0.0.0
0040: 20 61 74 20 6f 66 66 73 at offs
0048: 65 74 20 30 30 30 30 30 et 00000
0050: 30 30 30 000
It seems like it started when I added the latest updates and hotfixes that came with the evaluation download. It did not crash before I applied the hotfixes and updates. This is a test machine with only Orion and the eval of Engineer's toolkit on it. There are not other applications or software installed and I have all the latest microsoft updates. One of the nodes I try to expand is a Windows Server 2003 machine, another is a wireless node, and another is a Unix box. The ones that crash will not let me delete them either. I can add them into Orion a second time and they work just fine but I have two instances of the same node. No matter how many times I right click and delete the node, it still stays in the view. I thought about removing it from the database but that was a last resort. Does anybody have any suggestions other than trying a reinstall? Thanks for your help.
