All - New to Thwack. Hopefully this is an easy one.
Configuring SNMP connection to a Cisco UCS 220 server, running recently-upgraded CIMC version 4.0(4h). I would think this would be simple, but it's been fighting me. Wondering if someone could look at my config:
On Solar Winds Node:
View Type: Default
Polling Method: SNMP & ICMP
SNMP Version: SNMPv2C
SNMP Port: 161
Community String: Public
On CIMC Page: Admin > Communications > SNMP
SNMP Enabled
SNMP Port: 161
SNMP Access: Full
Access Community String: Public
Getting the following message from Solar Winds: "Unable to validate this node with the supplied SNMP credentials. Are you sure you want to update this node?"
Just don't understand what it doesn't work. I'm sure I'm overlooking something.
