SolarWinds Orion version 8.1 Hotfix 3
Hotfix 3 resolves an issue with adding nodes to Orion using
SNMP v1 or SNMP v2c community strings. The error received
is:
'The node xxx.xxx.xxx.xxx does not respond with the community string xxxxx'
Hotfix 3 also resolves the issues fixed in Hotfix 2. See hotfix 2 for details.
* Fixes issues with retrieving resource information, including
interfaces, from Extreme Networks ExtremeXOS devices
* Fixes issues with retrieving resource lists, including interfaces,
from Foundry devices
* Fixes an issue with adding devices containing consecutive zeros
in their IP addresses.
Hotfix 3 requires Orion version 8.1.
To install this hotfix, run Orion8.1Hotfix3.exe
The following file, using the default installation path, is
updated during the execution of the hotfix:
C:\Program Files\SolarWinds\Orion\orionnetperfmon.exe
The Hotfix can be downloaded here:
ftp://ftp.solarwinds.net/Orion/Hotfixes/Orion8.1Hotfixes.zip
