looking to hear form anyone who has this installed in their corporate environments and like to hear what you think of the product. I am contemplating getting this for my company.
Are you planning on using it by itself, or with ConfigMGR?
it will be sitting with SAM
We use ours with Microsoft Configuration Manager and for this use I would not recommend it. It is not as easy or as "clean" of an integration as one would think.
However, I can see where it can definitely add a nice feature set onto a standard WSUS environment.
If I wouldn't have just spent months trying to perfect my ConfigMGR patching process I would honestly utilize Patch Manager as a tool.
Can I ask what you are wanting from it?
I am currently using WSUS and need an automated solution with better functionality.
Just need a solution that work to patch machine in an effective way.
Looked at SCOM but to much functionality that we wouldnt touch and wasnt cost effective.
Ok, I will recommend patch manager then
Some of the third party patches it claims to do still require some "leg work" but other than that I feel it will make a great add-on to your wsus environment. (for reasons i stated above).
Thanks for the feedbackfcpsolaradmin but has anyone any thoughts on it.
