Hi All,
What are the parameters that SAM can onitor for windows and linux servers .Can anyone share .
That's a very broad question. Honestly, SAM can do just about anything when monitoring Windows or Linux. Do you have a list of requirements that you need to confirm? That would probably be the easier route.
I found the following to be very helpful if you are going to be using agents:
Monitor with Orion agents in SAM
The following docs would be of help if you are looking for a list of items that "can" be monitored by SAM:
Server & Application Monitor Template Reference
Component Monitor Types
