Hi all,
I have installed orion modules version 2019.4-HF1 using SQL_Latin1_General_CP1_CI_AS as database collation. And i found the Chinese characters in database cannot correctly displayed. So i need to change database collation from SQL_Latin1_General_CP1_CI_AS to Chinese_PRC_CI_AS.
I have searched in SuccessCenter, found a related article as below link.
https://support.solarwinds.com/SuccessCenter/s/article/Supported-SolarWinds-Orion-database-collations-for-Orion-Platform-2015-1-or-later
I executed below command to change database collation:
sqlservr -m -T4022 -T3659 -q"Chinese_PRC_CI_AS"
At the end of command output information, i see some error as below. It seemed the database collation change failed.
2020-01-27 17:43:33.81 spid5s index restored for SolarWindsOrion.UDT_Port.
2020-01-27 17:43:33.84 spid5s Error: 1934, Severity: 16, State: 1.
2020-01-27 17:43:33.84 spid5s UNKNOWN TOKEN failed because the following SET options have incorrect settings: 'ANSI_NULLS, QUOTED_IDENTIFIER, CONCAT_NULL_YIELDS_NULL, ANSI_WARNINGS, ANSI_PADDING'. Verify that SET options are correct for use with indexed views and/or indexes on computed columns and/or filtered indexes and/or query notifications and/or XML data type methods and/or spatial index operations.
2020-01-27 17:43:34.04 spid5s Error: 3434, Severity: 20, State: 1.
2020-01-27 17:43:34.04 spid5s Cannot change sort order or locale. An unexpected failure occurred while trying to reindex the server to a new collation. SQL Server is shutting down. Restart SQL Server to continue with the sort order unchanged. Diagnose and correct previous errors and then retry the operation.
2020-01-27 17:43:34.04 spid5s SQL Server shutdown has been initiated
2020-01-27 17:43:34.04 spid5s SQL Trace was stopped due to server shutdown. Trace ID = '1'. This is an informational message only; no user action is required.
Attached file is the command running full log.
Could somebody help me?
