Is there a way to speed up the loading of the network map? I have it on my home page now, and it takes 10 to 15 seconds to load the home page. if i remove the network map, it loads in less than 2 seconds. I have no backgrounds on the map and am using the smallest (is file size) icons available. I only have 5 icons on the main map page but they link to other maps which have all the nodes broken down by state. Orion and poller are on 1 server and the SQL database is on the other. Both VMs are connected via a 1 gigabit connection to the network fed with a 10 gigabit fiber backbone.
VM1 = Server 2003 R2 SP2, Intel Xeon 2.33GHz, 1gig RAM = Orion and Poller
VM2 = Server 2003 R2 SP2, Intel Xeon 2.33GHz, 2gig RAM = SQL Database
Both VMs are on a Priority One Cluster
Database details are below:
| Operating System | Windows 2003 Standard Edition |
| OS Version | 5.2.3790 |
| Service Pack | 2.0 |
| Catalog | NetPerfMon |
| Database Engine | Microsoft SQL Server |
| SQL Version | Microsoft SQL Server 2005 - 9.00.3042.00 (Intel X86) Feb 9 2007 22:47:07 Copyright (c) 1988-2005 Microsoft Corporation Standard Edition on Windows NT 5.2 (Build 3790: Service Pack 2) |
| Security Model | User Name \ Password |
| User Name | SolarWindsNPM |
| Connection Timeout | 20 seconds |
| Network Elements | 927 Elements |
| Nodes | 344 Nodes |
| Interfaces | 583 Interfaces |
| Volumes | 0 Volumes |
| Alerts | 0 Alerts |
| Events | 2183 Events |
| Pollers | 1845 Pollers |
| Polling Engines | 1 Polling Engines |
