Has anyone gotten this to work and is using it?
I am running Orion 8.5.1 SP3 and am having no luck with this. The problem first appeared when I was trying to use PSEXEC to play a sound on a remote system. The Alert Log said it worked but nothing played. After doing some testing with tech support I decided to try a different approach....
I have tried to get the External Program alert to simply open Notepad.exe on the Orion server. I have tried this in both basic and advanced and get the same results - the notepad.exe shows up in the task manager (User Name System)processes but not under applications.
I have checked (double and triple check) and restarted the service to make sure the Alert service is set for Local Account/Interact with Desktop. I have even tried a domain service account.
I am at a loss as to what else to check or try. So if you are using this feature please let me know how.
