Just wondering whether the Wireles Network Monitor allows you to change WAP's settings e.g. the encryption keys etc?
If it doesn't does anyone else use another product to manage multiple Wireless Access Points across WAN's?
Many Thanks,
Paul
Hi Paul,
It monitors but does not manage the configurations.
Network Configuration Manager might be what you are looking for. You can upload command scripts and thus modify the Access Points configurations.
You can backup/upload the configs as well...etc.
You can try it for 30 days to ensure it works with your Access Points.
www.solarwinds.com/.../network_configuration_management_compliance.aspx
thanks
Yann
Thanks for the pointer Yann, will have to try it after upgrading our Orion installation!
Cheers,
