Working on setting up custom mib polling for IBM RSA adapters.
The IBM README indicated it should be 1.3.6.1.4.1.2.3.51.1
Orion only has 1.3.6.1.4.1.2.3.51.2 - that OID is for their bladecenter management adapter, not the RSA adapters. By the way, that OID using custom MIB polling works on my bladecenter. :-)
From IBM RSA MIB README file:
RSA-MIB DEFINITIONS ::= BEGIN
IMPORTS
OBJECT-TYPE FROM RFC-1212
enterprises FROM RFC1155-SMI
-- DisplayString FROM RFC1213-MIB
IpAddress FROM RFC1155-SMI
TRAP-TYPE FROM RFC-1215;
-- IBM enterprise group
ibm OBJECT IDENTIFIER ::= { enterprises 2 }
-- IBM products group
ibmAgents OBJECT IDENTIFIER ::= { ibm 3 }
-- IBM e-Server Advanced System Management Support Processor(SP) agent group
netfinitySupportProcessorAgent OBJECT IDENTIFIER ::= { ibmAgents 51 }
-- IBM Remote Supervisor Adapter (increase this number for follow on SP's)
-- Also known as Advanced System Mangement(ASM) SP
ibmRemoteSupSnmpMIB OBJECT IDENTIFIER ::= { netfinitySupportProcessorAgent 1 }
