Recently, I tried to use Solarwinds Netflow to track down a rogue application on my network.
I knew the rogue application was running in a high range of ports....but those fifty or so ports in the range were not defined in the Application and Service Ports table.
When I drilled into the conversations, Netflow just listed all those undefined port ranges as "Unmonitored Traffic(-1)".
Would it be possible to create a hotfix file that lists every single port number up to 65535....and at least list the applications name as being the port number... if no pre-defined name exists.
Example: port 48000 would be named application "48000"
That way we could use the search tool to find ANY port in use and when drilling into a Netflow conversation, we could see the port # in use instead of seeing "Unmonitored Traffic(-1)". That would really be great.
