Orion is showing a Cisco device with multiple reboots, over 4,000 so far. Is this a Cisco OS issue or an Orion?
Device is a C3750EImage is C3750EOS Version 12.2(44)SE2, Release Software (fc2)
Its hard to tell from this info. Where are you seeing that it was rebooted. Do you have an alert firing?
Sorry, thought I had provided 'nuff info.
The multiple reboots are showing up in the events for those nodes. This just started when we changed them from SNMPv2 to SNMPv3. I 'suspect' it might be the OS version on those 2 switches.
Remember that reboot from an SNMP standpoint means that the SNMP stack rebooted. This can also happen when you make configuration changes to SNMP on some platforms. Clearing SNMP stats may also trigger this.
