Hi guys,
How can I turn the display settings {0} bytes to something more readable such as GB or MB?
Custom SQL?
Thanks.
One thing to note; I noticed when I was creating this that the "Available Space" column did not show in my initial report. Check your column widths! (Took me a few minutes to see that the default for the report is 'Custom')
This is from http://oriondemo.solarwinds.com/ to ensure it is the default report that comes out of the box (except for the last pic as I needed some live data):
Original Results (after following all of the steps outlined above)
Step 1 - Edit the column widths
Step 2 - Set you widths so that you can see the far right "Available Space" column (I went with 'Automatic')
Final Result:
Edit the table and you can change the output here:
Thanks....Looking for Available Space not Volume Size which does have granular capability. Available space field does not:
you need to remove the custom format display option and add the data unit option (you won't see data unit in the drop down until you remove custom format)
-ZackM
I added it but for same odd reason the field does not appear in the report. I added the custom view per your screenshots.
Can anyone take the canned report and show me adding this field and custom view actually works?
Thanks for your help.
Thanks. I will try it tomorrow. Yes, I experienced the column issue too but I got distracted and didn't keep at it, but yes, I could sense something was up when going into Preview Mode. Thanks for your help.
Thank you so much for taking the time to help. I'm not getting the same results.
Anything obvious here?
Ok, I got it..... Thanks man.
