I need to know if there is a way to refresh the SSH key within NCM. I have a few devices that are getting connection refused when trying to execute a script using SSH. I am able to SSH directly to the devices from putty with out issues.
Using the test function under the edit node for NCM fails. If I un-manage the device with NCM save it, then re-manage the device in NCM it corrects this. I assume that NCM has some sort of cache where the SSH keys are, if so can this be cleared to force it to update? Or will I have to unmanaged all devices with issue and re-add to get them to work?
Michael G
