I've got some new Cisco Nexus 7710 with brandnew NX-OS 8.0(1) which i want to use as cores for my access-layer.
Today i've tried to get nbar working but i can't find the relevant commands.
I found this on cisco page:
Enabling Protocol Discovery on an Interface
Perform this task to enable protocol discovery on an interface.
SUMMARY STEPS
1. enable
2. configure terminal
3. interface type number [name-tag]
4. ip nbar protocol-discovery [ipv4 | ipv6]
5. end
On my router it looks like:
(config)# int eth1/1
(config-if)# ip nbar ?
% Invalid command at '^' marker.
Orion config example shows:
flow record NTArec
match ipv4 tos
collect counter bytes
collect counter packets
collect application name
My router shows;
(config-flow-record)# collect ?
counter Counters to collect
low Flow identifying fields
ip IP attributes
routing Routing attributes
timestamp Timestamp fields
transport Transport layer fields
The feature is enabled:
Feature Name Instance State
netflow 1 enabled
Does anybody know how to get NBAR configured on the Cisco Nexus Chassis?
