Hi
I'm trying to configure NTA on Cisco 2960C with no luck.
Is there any specific configuration needed for this model ? It seems to support Netflow as I'm able to run all commands with no issue provided here as a sample, But for some reasons it's not showing up in NTA interfaces.
Cisco 2900 series routers sample configuration for NTA - SolarWinds Worldwide, LLC. Help and Support
show ip flow export shows 0 flows exported in 0 udp datagrams
If it doesn't support Netflow, How it can be monitored using NTA?
