Hello,
I am trying to set up Solarwinds NTA but I am having a bit trouble conceptulising the deployment and configuration. Can someone advise on which ports Netflow should be enabled within a multi-campus network environment?
I have three sites A, B and C that are connected with WAN links (A to B, B to C and C to A). There is a Cisco 3850 core switch at each site which is capable of doing Cisco Flexible Netflow. My question is on which interfaces should I enable Netflow on the cores?
I presume to enable it on the L3 WAN Link ports between each of the sites.
1. Should I enable Netflow on the trunk ports between the Core and Edge Switches at each site?
2. For each interface where Netflow is enabled, what direction should it be enabled for (Ingress, Egress or Both)? I did find this article which said not to enable both Ingress and Egress capture for Netflow interfaces due to double-capturing data. But if you just enable Ingress monitoring on each interface then the Egress statistics in NTA are blank. Should this be how it is done?
3. How is traffic between two ports on the same VLAN, on the same edge switch captured by Netflow? Or is NTA with Netflow only designed to capture routed traffic?
