Kiwi Syslog 9.2.1 says that it is required version 2.1.0.3 or higher but I can find 2.0.9 version only from the official website! Where can I download the needed version ?
When Kiwi Syslog tries to install this required component it says "instaled" but something is still required when I go back I see that the UltiDev Cassini Web Server is still ticked.
Thank you
The HRESULT 0x8007007E is "The specified module could not be found."
{72C24DD5-D70A-438B-8A42-98424B88AFB8} is Windows Script Host.
Download and Install Windows Script Host from Microsoft and you should be fine.
Window Script Host 5.7 for Windows 2000:http://www.microsoft.com/downloads/en/details.aspx?FamilyID=c03d3e49-b40e-4ca1-a0c7-cc135ec4d2be&displaylang=en
When you run the installer we ask if you want us to install the web component and that should setup everything you need. Sounds like this is not happening correct? Can you give more info on your platform, what OS are you installing on?
So, I'm running Windows 2000 SP4
In the first screen you can see that I need only UltiDev Cassini Web Server
then I press next, it installs the pack but then this error appears:
when I press back, I see again the first screen, that I have to install the Web Server, I've tried to install manually the web server tacking the install from the official website. nothing changed, Kiwi Syslog doesnt detect it, as I see it need's version 2.1.0.3, but on the official website there is 2.0.9 only.
I am going to reach out to you offline to work through this, expect an email from me soon.
Thank you bshopp, but that didn't solved my problem, I get a new error when trying to install UltiDev Cassini Web Server 2.1.0.3, print screens:
The description for Event ID ( 11001 ) in Source ( MsiInstaller ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: Product: UltiDev Cassini Web Server for ASP.NET 2.0 -- Error 1001. Service Install():System.Runtime.InteropServices.COMException (0x8007007F): Retrieving the COM class factory for component with CLSID {72C24DD5-D70A-438B-8A42-98424B88AFB8} failed due to the following error: 8007007f. at CassiniService.ProjectInstaller.CreateProgramIcon(String targetPath, String shortcutName, String iconLocation, String description) at CassiniService.ProjectInstaller.CreateShortcuts() at CassiniService.ProjectInstaller.Install(IDictionary stateSaver) --> Retrieving the COM class factory for component with CLSID {72C24DD5-D70A-438B-8A42-98424B88AFB8} failed due to the following error: 8007007f.; (NULL); (NULL); (NULL).
Can you fill me in on how to fix this problem that I saw on the forums? I'm having the same issues:
Don Dao
