Wondering if this is by design. I would have expected it to blank out all fields for that Node/address
thx
arg, it works now. apparently I didn't test this when updating to 2.0.1. I asked support to close the ticket.
thanks
Larry, what version are you running?
This is not expected behaviour. The custom fields should be blanked when the status changes to available.
If you are not running the latest version (2.0.1), please upgrade to that and if you are still experiencing the issue, we will need to investigate further (diagnostics, support case, etc.).
Mav
I am running the latest. I'll open a case and post info here.
Ok, we weren't able to re-produce the problem here so that would be good.
Thanks.
case 257735, uploading diag in a few, when it finishes.
