Hi there.
I'm testing an evaluation version of IP SLA and have hit a problem.
I've got a few suitable routers in use and have added them as IP SLA Nodes with Read/Write SNMP strings , then defined a few test SLA Operations (UDP Jitter , VOIP UDP Jitter and TCP Connect).
They appear to be running ok and show up in the Operations Help Overview as UP , but when I go into the details of the operation , all the graphs are basically blank. I get the text descriptions such as "Min/Max/Avg graph of jitter" but that's it. The dials on the left side of the screen do show the numeric values so it seems to be running but not storing any data.
Am I having a dumb moment here , or is something not working as it should?
