Hi
We want to put a server as a portal for our customers, this server will communicate with Solarwinds to get reports on IP SLA operations, what is the best way to integrate Solarwinds with portal server??? and if possible get the API used??
Regards
Hi, I suggest you to download the Orion SDK package (from ) and read the Technical Reference document once installed, unless you already did so. You can find an overview and introduction there about SolarWinds Information Service that you can use for accessing data managed and polled by IPSLA operations.
You may also be interested in the forum covering SDK related questions.
