I, and hopefully many others, would find it useful to be able to unmanage IPSLA monitors.
thanks
+1 for sure!
doing "unmanage" IPSLA monitor you would expect that operation will still exits on Cisco device but you don't care about statistic poling right?
correct, and SW would not show the red dot indicating child object status down issue, but grey or blue (whichever it is)
thx
ok thanks.
and how often/why you want to do that? You would like to pre-configure SLA operations and then just monitor some of them depends on situation?
that's one option (i script everything out to start and we enter when adding connectivity). Another thing is if a customer leaves or moves connectivity to another headend device, and our paper process is behind for deletes (which it usually is), I'd like to be able to unmanage that to keep the system usable. as soon as one SLA is down and we know it is going to be down, we have no easy way to monitor the rest of them without adding another page for our ops to stare at .
Thx
