I am trying to track down a problem with the IP SLA Evaluation version. It seems I can only add 1 SLA node. I've tried removing the 1 previously added and it still will not add any of the others. Some of the nodes have different SNMP RW strings but I've tried adding nodes with the same string as the one I am able to add and it still fails.
What happens is I select a node to add, click "Add Nodes", and then it just sits there with the web page slightly grayed out. After a few minutes, it fails with no visible messages, the page goes 'bright' again, and that's it.
Is the evaluation version limited to only a single node being added? I've verified and re-verified SNMP strings. Where should I start looking to track this one down?
