The VoIP Monitor v2 Release Candidate is now available for download for all Thwack users. You have the opportunity to load the latest and greatest VoIP Monitor release before we officially announce the release. The updates for this release are as follows:
Manual call path configuration – VoIP Monitor no longer requires the read/write community string in order to collect IP SLA data from your VoIP call paths. You can now manually configure IP SLA on the IP SLA capable Cisco switches and routers. The option for VoIP Monitor to auto-configure IP SLA via the read/write community string is still present and the default option. Note: You can set up VoIP Monitor to auto-configure IP SLA operations for all devices with read/write access and to discover the IP SLA operations from manually configured devices.
Call paths are now set to run lifetime – VoIP Monitor v1 call path operations were set to run for 1 hour, which is the default IP SLA value. After an hour, VoIP Monitor would recreate the operations using the read/write community string. VoIP Monitor v2 now sets the operations to run forever and therefore the read/write community string is not used again by VoIP Monitor until the device is rebooted, IP SLA settings are modified, or the call paths are deleted and recreated by the user within VoIP Monitor.
Multiple VoIP Poller support – Users can deploy VoIP Monitor on multiple Orion pollers in order to manage larger deployments, deployments where each server has limited access to devices, or where the same IP address space is managed by multiple servers. Additional CallManager data collection and graphing – VoIP Monitor v2 monitors rejected phones, rejected gateways, and the operational status of each connected phone.
CallManager Alerts – CallManager alerts are now part of VoIP Monitor and several advanced alerts such as Alert me when unregistered phones are above 5% are available by default.
Updated Gauges and the ability to choose desired gauge – Slick, new gauges are available for representing call paths stats including Jitter, MOS, Latency, and Packet Loss.
Improved scalability – VoIP Monitor v2 handles larger VoIP deployments.
Improved navigation and usability – VoIP Monitor includes a Quick Start screen to help get started on setting up VoIP Monitor. Additionally, VoIP Monitor includes navigation to guide you through the Settings.
The licensed version is available in your Customer Portal under the Downloads section.
If you have any issues downloading the Release Candidate or experience any issues with the updated release, please let us know by either posting to this thread or by creating a support ticket at https://forms.netsuite.com/app/site/crm/externalcasepage.nl?compid=638609&formid=12&h=3d0552f20b2e9bd6580b
