In "Form Mode" is it possible to add "OR" or "AND". Can that only be done in "Editor Mode"
I am running Virtualization Manager v5.1.1.290
Can you post a couple of screenshots of what you are trying to do?
Here is a screenshot. Basically, I am trying to build a query to search for VM's with that end in WEB OR SQL. AND Powered On, and other attributes. Query fails if I add "OR".
Hope that makes sense. I am also a newbie when it comes to query so If you know a better way that would work too.
Thanks!
if you are in Advanced Search editor then press "Editor Mode" button:
After that you can insert attributes (No. 1) or type your own complex queries directly into editor (No. 2):
Hope it helps.
Thanks! It helps...I just need to learn how to write better queries.
