I'm currently setting up our Solarwinds environment (2022.3.0) and have a number of network maps which were used for testing that I would like to delete from Solarwinds/Orion database.
What is the correct way to go about this?
Cheers,Bevan
On version 2020.2.6 I was able to launch Network Atlas on the Orion Main Poller under Start - Solarwinds - Network Atlas
Expand the Maps section, right click on the map and click Delete.
The tool has been deprecated Orion Platform 2020.2.4 Release Notes (solarwinds.com)
If you can not launch Network Atlas I would suggest contacting support.
When you save maps from a node view they end up in this space:
My Dashboards - Home - Orion Maps
You can place a check in the box next to the map and delete them here.
Hi there,
There is no maps listed there unfortunately.. I should clarify, these were maps created with Network Atlas.
Ahh fantastic!! I dunno how I missed that in Network Atlas.. That worked.. Thank you very much
