This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Linux is not sending Netflow traffic
I have installed fprobe on ubuntu and also added it with SNMP. I can see data using wireshark on solarwinds server coming on port 2055  but unable to see it in NTA. One interface of the linux i showing in unsupported. Please  guide.
fprobe command:
sudo fprobe -fip -x0:0 -B4096 -b10 -r2 -q10000 -t10000:10000000 -n 5 -e 10 -d 10 -a 192.168.0.21 -i eth0 172.172.20.20:2055
  • what version of Ubuntu?  the 20.xx trains automatically enable the firewall (ufw), so you need to add udp2055 using "ufw allow 2055 to 172.172.202.20:2055" i beleive.
    you can also use netstat on the ubuntu box to verify your actually sending the data.
