We used to be able to click on the heading in our dashboard and it would follow the link to the Details about that dashboard group. Now it does nothing...
Anybody else seen this?
Elias
So what happens when you click the link? Does it do anything at all - i.e. does it attempt to go and just reload (as if an ad blocker was stopping it)? Does the URL show up when you hover?Have you tried other browsers?Also have you checked the link itself is still valid?
Hi EliasWe are seeing something very similar for one of our customers and I have a case open with SolarWinds. Can you please test clicking the image / icon with the arrow in the top right of the widget. We have found that you can still right click to load the page. In fact I have just tested this on another customer's instance and seeing the same so think it's a wider problem - maybe with HF5?
we've updated our test system to HF5 and seeing the same behavior so would say it's a HF5 problem.
Thank you for sharing this. This is a known issue that has been fixed in the 2022.3 release which is currently at RC1 stage.
No problem at all. Glad it's a recognized issue!
Thought I was the only one or going crazy, phew!
