How WPM works?
It is a pretty straightforward process.
But you have to understand the requirements, first.
The WPM module works according to THREE main steps.
01.) It records a website transaction.
02.) It plays the recording.
03.) It compares the performance in each of the played back steps with the recorded performance.
There is a Recorder and a Player.
You can record the transaction from the Main Polling Engine and play it back from another player location to measure user experience from various parts of the network.
Suppose the player location is different from the recorder location. In that case, there can sometimes be issues, which you can get around by making a new recording at the player location and playing that back rather than the centrally recorded transaction.
You can also check whether the issue is related to the site where the player is located by playing the same recording from a different location.
I just thought of sharing this knowledge which might be helpful for the community.
