So... If I am polling a node with a Linux agent and the "Status and Response Time" is check off on agent I assume that if the agent loses connection it will read the server as down... right?
Conversely if the "Status and Response Time" is check off on ICMP, would the server still read as UP even though the agent is not working...? Thanks.
