This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
SMI-S Configuration for IBM DS8870
I have tried several times to get Solarwinds to detect the IBM DS8870 storage array without any luck. According to IBM, the SMI-S is built into the Hardware Management Console (HMC) code and is enabled by default. Has anyone been successful in integrating the array into Solarwinds 6.5? If so, please provide me your procedure that you utilized. If you tried and failed, what was the issue you were running into?
