Hi... anyone have any success monitoring IBM Flash array's.....IBM 820 or IBM 840 Arrays?
Hi tmeyers,
The IBM Flashsystem 820/840 arrays are not supported in Storage Manager currently. If you'd like to request support for this device family you can vote on the idea here: http://thwack.solarwinds.com/ideas/3158
Do you know if the Flashsystem devices are supported by IBM SMI-S Provider? I didn't see it listed here: SMI-S Conformant Provider Software for IBM If not, are you aware how other monitoring tools collect data from this array? (e.g. SNMP, command line)?
Hi, Thanks for the reply..... I'll request support per your link above. SNMP doesn't provide a path to get much info on these devices.... given that the Flash Array space is really going to heat up in the near future I think there will be a huge demand for rich monitoring tools......
