I wanted to know if there are plans to support Nutanix monitoring.
hnz980 wrote:I wanted to know if there are plans to support Nutanix monitoring.
hnz980 wrote:
Yes. we're working on this now, let me know if you're interested in chatting with me on your use cases and we can set up a call!
I second this.
We are planning a migration off of our existing infrastructure across to Nutanix and would love to be able to continue to monitor the stack down to the storage level.
We have added our current Nutanix nodes using custom pollers so far but it does not give us the level of monitoring that we have been used to with out NetApp storage in Solarwinds (Although it's worth mentioning that Nutanix do have this covered exceptionally well themselves for their own stack).
Any plans or road maps around SRM integration with Nutanix as a storage appliance would be greatly received.
There is support for monitoring Nutanix.
https://www.nutanix.com/2015/04/23/nutanix-is-now-validated-for-solarwinds/
Through the UnDP package SolarWinds NPM administrators are now able to monitor Nutanix objects and components such as clusters, containers, storage pools and disks; and are also able to oversee important metrics such as latency, IOPs and bandwidth utilization.
I believe hnz980 is referring specifically to SRM monitoring. The method described in your link is for NPM SNMP based polling where SRM mostly uses SMI-S. Solarwinds supports Isilon and Equalogic arrays which also use SNMP so the capability seems to be there but so far Nutanix hasn't made the cut. I believe there are a few feature requests relating to this out there.
-Marc Netterfield
Is there any likely update for this request?
We are migrating to Nutanixs next year with intention of moving off of VMware onto AHV as well. Assuming this migration goes well its possible we will migrate another datacenter to Nutanix, that current DC uses a Storwize V7000 which SRM supports (happily running a trial at the moment) but I can't push for us to purchase SRM if it cannot be used or is unneeded if Nutanix replaces the existing solution within 16 months.
Regards
Nigel
I like the single pain of glass solarwinds and am still looking forward to the integration but but Nutanix has a great resource monitoring view.
Do you have a view for your nutanix environment that you could share or wouldn't mind sharing?
Any update on this... migration to Nutanix AHV is on our immediate horizon as well.... would rather not have to go to another product to effectively monitor this.....
We have been seeing more and more customers getting or processing POCs for Nutanix and HyperConverged in general.
A steer on inclusion would be useful
nutanix dashboard is powerful. I would love to see it integrated into Orion somehow but the customer would need VMAN/SRM/SAM to show the data that Prism shows.
//My opinion not solarwinds
True enough. But we also need the disk and IOPS data into SRM so our drill down where we "chase the problem" will work properly. No SRM, then you really are not a Storage Resource for the Orion tools.
tmeyers wrote:Any update on this... migration to Nutanix AHV is on our immediate horizon as well.... would rather not have to go to another product to effectively monitor this.....
tmeyers wrote:
nbs wrote:Is there any likely update for this request? We are migrating to Nutanixs next year with intention of moving off of VMware onto AHV as well. Assuming this migration goes well its possible we will migrate another datacenter to Nutanix, that current DC uses a Storwize V7000 which SRM supports (happily running a trial at the moment) but I can't push for us to purchase SRM if it cannot be used or is unneeded if Nutanix replaces the existing solution within 16 months.RegardsNigel
nbs wrote:
edsando wrote:True enough. But we also need the disk and IOPS data into SRM so our drill down where we "chase the problem" will work properly. No SRM, then you really are not a Storage Resource for the Orion tools.
edsando wrote:
Are you looking for disk level IOPs, & latency, storage container level iops and latency or storage pool iops and latency?
Costs would be an issue for VMAN/SRM at the moment. Dates increase over time, but budgets often don't Same ole story!!
nbs wrote:Costs would be an issue for VMAN/SRM at the moment. Dates increase over time, but budgets often don't Same ole story!!
Same ole story indeed! I'd still love to have a quick chat with you if you're interested. I'll direct message you with contact information.
