Hi all,
The SolarWinds HCO does not have internet access, it operates in offline mode.Is it possible to display clocks in this mode in a widget?
Thanks in advance!
Kind Regards,
Attila
Or below to get the current time.
SELECT TOP 1GETDATE() AS [DatetTime]FROM Orion.Nodes
Put it in a custom query widget. Not very pretty but works...
My first thought... No, you can't pull in extra code to make a clock.
Butmaybe you don't need a clock, you need the time. Can you can cheat and do something with the last poll time maybe? We have more than enough nodes polling for the time to appear current.
SELECT TOP 1 N.LastSystemUpTimePollUtc) as TimeFROM Orion.Nodes N Order by N.LastSystemUpTimePollUtc DESC
Use the functions here to format it: SWQL Functions · solarwinds/OrionSDK Wiki · GitHub
Thank you for your quick answer!
It is working.
D'oh! yah that's better Seashore
Thank you for your answer too! Your solution works too.
