I am faing issue in Enable/Disable of components is not working for Appinsight Templates in SAM. I want to use this functionality because when i am assigning the template to a particular node it is showing few components as unknown because those nodes are not available on that particular node and i am not able to disable that component for that node.
Please could you suggest why it is not working like other application monitor templates.
Also, I want to know about "Enable Performance Counter" option. If i check this option to get the data for all users logged in will it affect the performance of my Domain Controller.
Regards
Pushkar Dubey
