My team would like to create a customize template where we will consolidate all the services and performance counter of different servers. Here's the challenge that we're facing: every time we add the component(s), we have to disable the component(s) that are not available from the added servers of this customize template.
Would like to ask, is there a way where the component will be disabled upon adding them to the customize template and will manually enable on the dedicated server upon assigning this template?
Note: already tried to disable the component from the customize template (original template) and no data showed when you manually enabled the component from the dedicated server(s) assigned.
