Application Dependency Polling not Working on Clustered Database
I'd like to get the Application Dependency Polling working in my environment. It works fine on the few things I have that have non-clustered SQL servers.
However, the majority of my applications (the ones I care most about) use various SQL clusters on the back end.
If that's the case application dependency polling does not seem to work.
I have the agent installed on both nodes in the cluster, but when I try to turn the feature on it doesn't show any dependencies.
I need it monitoring through the cluster name, and not the node name as the active node changes periodically.
Has anyone got this working using a SQL cluster back end?
