I need to use a third party cmdlet in a powershell monitor... The cmdlet in question is NetCmdlets from powershellinside dot com.
When running locally on the Orion server through the PowerShell ISE, I get the expected output, when running in APM I get this:
The term 'get-imap' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
Script arguments:
-server "servername" -user "username" -password "somethingelse"
Script body:
param( [string] $server = "",
[string] $user,
[string] $password,
[switch] $pop)
if(!(Get-Module | Where {$_.Name -eq "NetCmdlets"})) {
Import-Module "NetCmdlets"
if ($server -eq "") {
$server = read-host "Mail Server [localhost]"
if ($server -eq "") { $server = "localhost" }
if ($pop) {
get-pop -server $server -user $user -password $password | sort Date -descending
else {
get-imap -server $server -user $user -password $password | WHERE-Object {$_.Subject -eq "Subject of an email message"}
trap{
write-host "Exception occurred (please find more information below), script execution was terminated."
break
