Are there any Powershell scripts available or some other way to perform a quick health check of the Solarwinds Poller?
Also can some one provide the list of things need to be validated to check if everything is working on the pollers?
Can some one help me?
i think this is what you are looking for:
There is an alert which can set on your poller if its not alive for x minutes. This will help u keeping a watch on it.
Also u can monitor the Solarwinds services if u have SAM plugin. OR u can monitor it using other tool if u have in your enviroment
Here is a video on how to use active diagnostics. https://support.solarwinds.com/Success_Center/Network_Performance_Monitor_(NPM)/Troubleshooting_and_Support_-_Active_Diagnostics_-_Video
https://thwack.solarwinds.com/docs/DOC-170557#start=25
